Thread: Small Block Cam
Old 02-06-2011, 04:35 PM
blykins blykins is offline
Originally Posted by Wbulk View Post
This is a good article on the subject. Same engine as mine with three dyno pulls with stock and other heads with the same cam. The stock heads with a Crane cam #363902 pulled 285 hp at 5,000 rpms, and 273 hp at 5500 rpm. You have to click on related photos to the right and then click on the cam picture. At .050 it's 204-216 duration, lift is .456 and .484. The opening and closing specs are very, very, close to the Edelbrock cam.
http://www.mustangandfords.com/techa...dyno_test.html
I can get you a Comp cam (may save you some money as the Crane stuff is generally more expensive) that will meet your requirements. Keep in mind that a 302 with that cam will also sound pretty mild with just a noticeable idle.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
