Old 02-08-2011, 09:06 AM
legenmetals's Avatar
legenmetals legenmetals is offline
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
I'm using Qa1 adjustables with springs that were on the Konis.I checked the spring rates and they are 300 .lbs each. my car is a contemporary with Jag. rear end. I found that the larger the angle of the shock installation the higher the spring rate that is needed.I will try and dig out the Qa1 part number for you.
