Originally Posted by legenmetals
I'm using Qa1 adjustables with springs that were on the Konis.I checked the spring rates and they are 300 .lbs each. my car is a contemporary with Jag. rear end. I found that the larger the angle of the shock installation the higher the spring rate that is needed.I will try and dig out the Qa1 part number for you.
Thanks for the info. Please do let me know if you find a part #. I have had really good luck with the QA1's on my ford 9". I think the part # that I have on the ford 9" is DR4855P. Maybe I could buy 2 more and use them on the Jag rear as well?
-Mike
