Old 01-23-2002, 07:11 AM
PhilB PhilB is offline
Albright42-
I used 3 qts of color mixed 1:1 with reducer; 6 qts actually sprayed. Video available from Autobodystore.com for $29. I built a 2X2 wood frame and covered (from the inside with clear drop cloths. Forced air though an AC filter at the top at one end and discharged outside the garage though another filter at the bottom on the other end. Installed 8 inexpensive 2 lamp, fluorecsent fixtures outside the booth (hence the need for clear drop cloths) and on the sides. Washed the entire booth down with water before each use and left the floor damp during spraying. The outer end of the booth was removal so I could get the car in and out and I made a hinged door for easy access.
Chris Potter-
Paint is PPG Deltron 2000, Intense Blue Pearlcoat, #DBC5357T. I attached a photo (I think).
