Wow, looks fantastic, my floor goes in around the 28th, probably have to leave for a while to cure before coating, did the contractor do the floor grind ? The concreter i'm using will use a helicopter float to smooth, but whether this is smooth enough for the coating, i'm assuming probably not. Being a urethane top coat, sounds like a relatively easy repair if damaged, (not to deep).
Looks great
