Old 02-11-2011, 04:37 AM
treblig treblig is offline
Cobra Make, Engine: Midstates in-work again
Thanks FWD,
I did some research last night on installing a fuel pressure gauge. Also I am going to take one more trip to the DMV today here in Huntsville. I am going to remove my gas cap to see if it is a venting issue. If it is I will tap into my filler tube and vent down through the floor of the trunk to the outside. I have 3/8's ID fuel line which I am going to use. Do I need a larger ID tube?
Still going to install a fuel pressure gauge because next year I am thinking on buying a Ford create 351 motor and for sure will need a gauge. I just thought that it's a stock motor, no need to install gauge.
Will it you know if I got my plates or not
Jeff
Treblig
