Old 02-11-2011, 08:04 PM
mbeers6 mbeers6 is offline
Cobra Make, Engine: B&B,351w
Originally Posted by lnfletcher View Post
Curious, did you ever solve your problem?
Thanks for asking....yes and no.
The problem is for sure with the 16T driven gear. I put on my old 19T and the speedo works fine. Both gears are exactly the same length, same square bore inside, etc.
I ended up putting two marks on the gears so I knew where the flat ends of the square were inside.
I tried the 16T white gear again this time lining it up. Still doesn't work!! Funny thing is that the inside looks perfectly square, it's not chewed up as I expected.
I'm just going to order a new 16T driven gear and hope for the best. Thanks for all your help guys!
16T white gear inside view, appears to be fine.
Old Pink 19T gear with mark
