  #110 (permalink)
Old 02-11-2011, 11:23 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Originally Posted by slider701 View Post
OK........thought about it more. Come at it from the other end.........from the valve train side. Make the area where the valve seats are as a removable plate so you can get into the backside of the combustion chambers and intake/exhaust runners to machine the water jackets. It then becomes much easier to seal off the water jackets into the valve train area without having to worry about combustion gas pressures.
Yes, we have thought about that too and I think that is the only way that will work. We will have to keep the joint as far away from the combustion chamber as possible to keep the heat out of the seal. Still thinking on this one.
David
