Jeff
I have a Holley fuel pump for my EFI system.
It is a pusher pump. It needs to be close to the tank and as low as you can mount it to the bottom of the tank.
Maybe it's the location of the pump????? Something to check.
You can hook a hose to the outlet of the pump and pump the gas back into the gas tank. By doing this you could run the pump for 20 minutes to see if it stops.
Keep the faith, we can fix it.
Dwight
