Old 02-14-2011, 07:55 PM
wedgerton wedgerton is offline
Cobra Make, Engine: FFR MKIII 347ci stroker 450hp
Originally Posted by SSSammy View Post
What kind of problem are you having, Wayne? In TX you should have to meet the 1965 standards worst case ... a PCV valve. If you had your car inspected at the DPS Waiver station, you would have failed the OBD II emission test, then been given a waiver based on your 1965 replica status. Onward to registration with the "green" sheet. Probably ought to do this for the first time, then use the non-DPS inspectors for subsequent years.
Sam
Hi Sam,
I've past inspection, no problem, but was just cocerned if the year motor might catch me at registration. But apparently I've made it through inspection so I'm ok to go ?
Wayne
