I have 4 spring sets in the garage that are of the original diameter but three of the sets were made for me by Hypercoil and I am not sure about the stock ones but this is my best guess. 3.25 ID 11.68 O/l length 7 active coils with a .566 wire diameter F and the same dimensions with a .59 wire diameter rear. I think the rates were about 275 front and 320 rear but don't know for sure and did not calculate the rates based on the wire diameter I just listed. I can tell you these rates are no good for anything but the very small original blue dot tires. The wheel rates are in the 100 pound range and certainly not sufficient for any modern tire unless you like scary roll angles with bad geometry. Hope this helps
