Originally Posted by joyridin'
My Cobra had the Holley version when I bought it. I contacted Holley and they told me the carb was from the late 90's to the early 2000's. I got rid of it because of the throttle shafts. There were no bushings where the throttle shaft goes through the housing, and the shaft moved around about .05" from wear...probably due to a heavy return spring. Unlike the old Holley, there is no baseplate to replace, so it would have been a nightmare to fix. Hopefully Summit corrected this situation.
Like any carb they are easy enough to rebush.
4010 is an easy carb to modify and Summit has done a great job to fix the little "woes" and produce an even better, more tuneable carburettor.
Originally Posted by Xavier
I put the carb on when I got it in December or there abouts, it was running okay right out of the box, but needed to be tuned. I had to rejet, and adjust fuel level, minor adjustments I think you would do on any carb out of the box - same as I had to do on previous carb. I liked the look, the price and the performance. I have no issues. People either hated the 4010 or loved them, like anything else the people who hate something are going to speak louder. I have a racy cam on my 351, and like the carb before, I had to clean it, rejet it and tune it...
I've had 4010 750 DPs on 300 - 400 CID engines with great success. A very underestimated carburettor for those who aren't used to change.
