Went and looked at the blocks again. confirmed 2 are the Hipo blocks with the extenal weight on the crankshaft between the block and crankshaft gear. Both blocks have the bigger main caps and the larger rod bolts on the rods. I will now be going thru all the 289 heads to see if there are any Hipo heads as I've found these are different then normal 289 heads also. Any idea what a used and rebuildable short block is worth. both blocks appear to be std bore but will need to be cleaned up/bored. Thanks for any info and help.
