Old 02-22-2011, 01:32 AM
stephen low's Avatar
stephen low stephen low is offline
Zedn mate if SAI Global keep on certifying us it is hard to be unhappy. But their continued engagement is my boss's choice I suspect.
In any case this audit happened without any gap, internal or pre-audit testing to see if I had really closed all the potential holes in the system. So this makes me really happy. More a case of get them now or in several months, so it had to be done.
Anyway the heater I am using is a red dot which I think are generally those destined for use in excavators and the like.
Just has an open face so I folded the airbox out of aluminium to fit over the front with the two outlets and a slide to vary flow between either or share at a variable amount either way.
Plan is to copy the Vintage air black anodised 4 switch set they sell with black knobs and a black anodised backing plate etched with the control signs for a cluster of four control knobs.
This will generally match the white on black gauges and keep the dash to a fairly constant colour theme too.
slowy
