Thread: 64 289
Old 02-23-2011, 12:40 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by Rick Parker View Post
There have been from time to time on Ebay (and other place) advertised 4 bolt caps to the used as a replacement on "Stock" 2 bolt blocks. HOWEVER, from what I recall there isn't a lot of material (thick webs?) for the outer bolt holes to be machined into, otherwise I think it would be a more popular conversion.
I think a set of cross-bolted mains would be great.....not sure if there is enough skirt to bolt to, though. The mains would be quite "wide", that's for sure!! I could see an extra pair of small diameter main bolts in the webs and two more cross-bolted in. Sounds like it would be a great setup and not require a main-girdle.
Cheers from Doug
YD,E./PNB
No names were changed to protect the innocent!
