Old 02-24-2011, 01:57 PM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
Ground problem. You have to check ground continuity at the bulb contact. You cannot just verify the ground wire is attached. Taillights are finnicky about the grounds. The lower voltage on one circuit is due to the higher resistance (due to a poor ground) in that circuit, so you have a lower voltage. Your poor ground may be in the socket, so you must check the ground circuit with an ohmmeter. Anything more than about 0 will be problematic. Good luck finding your ground problem!
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
