Old 02-25-2011, 03:22 PM
redmt redmt is offline
Pull all the plugs and use the "finger compression test" running through the firing order as you do your leakdown. As soon as you have "finger pressure" you can run your test without having to run the engine around more than twice. Be sure to hold the crank when you put the air to it or it could send that cylinder to BDC.
