The dash light goes out when the I wire is backed out of the VR plug. Grounds checked good with Fluke and they are tight and clean. The Green/Red wires shows system voltage and when grounded the dash light comes on.
All points to a bad VR. I will pick one up and report back.
I did go ahead and solder the diode in the see it it improves the run on problem.
John
