Originally Posted by Fullchat289
Wow, Tim..Looks great! I love the look of the grill without the oil cooler scoop, a la street car.
Is that a 235/295 Firestone combination you will be running?
Any engine build progress you can share (Pics??)?
- Allen.
Thanks Allen ... The grille is pretty neat. You are correct, those are the Firestone 235 / 295 setup, Dangerous Doug has the same tires on 2108 and likes them. Not as high performance as the AVON tires, but a good set to start with.
Motor pics are coming soon, Tom at FE Specialties has the motor together and has run it in on the test stand. Once the Primary pipes are available from ERA, we will put the motor on the dyno and see what power we get from the 302
