Old 02-26-2011, 10:16 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Yes. Ff your pointer is correct.
But if you didn't chck that last time you had you rheads off or otherwise with thumb or TDC finder tool, then these are the options.
Then it's a matter of degrees if you find TDC on no. 1- although I do not have ( or bother to find out now) the degrees for the rest.
Anyway, what I should say was: I ordere myself a TDC finder for the plughole. All steel.
Did anyone use such a thing without getting piston top scratched? It's the stupidestr construction I have ever seen. They could, at least, put on a hard nylon/ PTFE or other tip on the tool to not destroy pistons... The Profom piece I will not tell you to get.
(And after trying 2 times, it was still 2 degrees off as I found out after taking the head off.)
RS
