Old 02-27-2011, 06:55 PM
cab cab is offline
Cobra Make, Engine: hurricane,# 1060
what kind of lube do you use on acc.pump,iwas thinking about unhooking the linkage and starting over,sometimes they will also drain gas out the bottoms and flood the top of the manifold ,i turn down the regulator down to 2lbs.carbs are syncronized,when it would flood out i woud see gas come out the thortle shaft is that what your talking about.
www.tni.com/craig-baker
