Originally Posted by xb-60
The tyre rating system isn't quite that simple. The UTQS (Uniform Tyre Quality grading System) for treadwear / traction / temperature ratings is an attempt to have a system for comparison of tyre properties. It’ s not perfect for a number of reason, but it at least provides some guidance.
Treadwear is based on a reference tyre that has a rating of 100, so a rating of 40 means the tyre will last 40% as long. Nothing else implied.
The traction rating is closer to a 'compound guide'. It is however a tyre’s traction rating on a wet road. Traction is rated as AA, A, B or C. AA is of course the highest rating.
Temperature is rated as A, B or C. It indicates a tyre’s resistance to building up heat (ie combination of generation and dissipation of heat). A is the highest rating.
Hope that helps.
Glen
Thanks Glen, I have read the UTQS, I thought by my using the word "guide" was suffice to indicate the relative inaccurate nature of the rating.
The UTQS mentions, it is common for DOT racing tyres to be assigned very low values - sometimes even zero.
So, IMHO, a tire with a WR of 80 will PROBABLY be softer than one with 440 WR. This information, IMHO, can be a usefull part of the equation (as well as speed rating, reviews, recommendations etc) in choosing a specific performance catagory of tires - Extreme, Max, Ultra, Grand Touring etc.
Of course with race tires, actual testing is the only way to determine what the best compound is for that individual/car/race.
................uh, nevermind
