Steve, the logs work because they are not wood. The smoke bonds with the creosote and makes it really brittle. The heat causes it to crack and fall and you end up with a bunch of brittle black pieces in your ashes for several months. I found a few treatments usually work best. It does not get as good as a chimney sweep, but it helps a lot and keeps it clear.
Why do they call it "Common Sense" when it is so rare?
