Old 01-24-2002, 04:11 PM
mikief mikief is offline
Cobra Make, Engine: FFR 1137 EFI 347
Also running an S-trim but into a 347. I'm pretty much cammed to the max, TFS heads, GT-40 upper, 80mm MAF, 42# squirters, and prog ECU. I dynoed a couple weeks back with T/A's ( considerable slippage) at 434 rwhp. Had the laptop hooked up and much to my surprise the 42's maxed out! He didn't have wide band O2 so couldn't tune. Will leave fuel map stock for now. Also showed over 1100 kg air at 6500 thru a 65mm TB!
