rims and tires
Don or DV what size rims and tires are the best combination for the CR. Don i have the 8.8 ford solid axle with disc brakes now and 15 inch rims. can you tell me about the rims. they are Halibrand knock offs i think. Can i go with a 17 inch rims and if so what kind of backspacing do i need/ have at this time. what is the widest tire you can get under the CR with out serious rubbing. mostly the rear the fronts are 15 inch 245/60 and seem ok. but i would like to have wider rims if possible.
thanks Mike
Well officer.. It was like this.
