Old 03-02-2011, 06:24 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
I noticed that the nut for adjustment is what is hitting. I did however adjusted the valves recently and the gasket is smashed thin. If I had thicker gaskets as when they were new it would not hit. Some have said to remove the baffle, I decided to do this and see what happens. If anything I will make a better baffle and reattach.
Apparently, this is some what common with the erson rockers.
I wonder if others have had this problem
