Old 03-04-2011, 03:57 AM
blykins blykins is offline
Originally Posted by fordracing65 View Post
yes its huge, but it has six different shifter locations
As does the TKO 500/600.
Here is a brief synopsis:
*If you want to go for authenticity, then go with the Toploader. They are plenty strong enough, even for big blocks. The only con here is that they have no overdrive.
*The T5 is too weak for a higher performance engine. I've seen many of them break in factory 5.0 Mustangs. They are, however, the lightest of any I'm going to name, and they shift really well.
*The TKO 500/600 is all-around the best bang for the buck. They will handle an enormous amount of power (500 lb-ft for the TKO 500, 600 for the TKO 600). Their ratings are in "continuous" torque, not peak torque. They are very strong. These transmissions do require a break-in period so that they will limber up. Otherwise they are quite notchy from the factory. They will bolt up to a Toploader bellhousing if equipped with a short input shaft.
*The Magnum T-56 is a nice transmission (rated for 700 lb-ft), but it's 1. Expensive 2. Long 3. Heavy. There's not many situations where this transmission is required and I hardly ever recommend the use of one. They are bigger in girth, longer, and weigh about 25-30 lbs more than a TKO. The transmission tunnels of some replicas will not accept them. They are made with hydraulic throw out bearings in mind (a big no-no in my book), but with modification, the midplate can accept a ball stud and a clutch fork. If you're running a solid axle car, this transmission makes the driveshaft even shorter, which loads the u-joints even more.
*The Richmond boxes are nice, but they too are very expensive. They are smaller in size so they will fit in a lot of transmission tunnels, but the shifter is an external linkage, like a Toploader, so you have to keep that in mind. The older boxes are rated for about 400-450 lb-ft, while the new stuff is closer to 600.
As far as pricing goes, you'll pay about $1500 for a rebuilt Toploader, $2195 for a TKO 600, $2795 for a Mag T-56, and up over $3500 for one of the nice Richmond boxes.
In my mind for a nice street car, it comes down to two choices: 1. Toploader 2. TKO 600. The TKO is available with two overdrive ratios, so it can be custom suited to whatever drivetrain combination you're working with.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
