Thread: Oil Temp
Old 03-04-2011, 02:30 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is online now
Comments in color embedded in the quote.
Originally Posted by bobcowan View Post
Oil is predominantly heated by rpm's. Consistantly high rpm's will heat up the oil like it should. A few rapid accelerations on the street aren't enough to get it really hot.
After a while, the oil temp generally stabilizes at around water temp.
I concur with both observations above. Driving around town won't do it. Get it on the freeway and oil temp == water temp. But it won't happen until the engine runs above 3000RPM for a while. From starting my water temp gets to operating in about 5 minutes; in stop and go oil will catch up in about 15-20. Mine is a Roush 427 and the oil temp sensor is in the pan.
If you have an oil cooler on a street car, your oil will never get hot. Unless you're driving in Phoenix in July.
It will warm up (as does water) in stop and go traffic, but like above, tends to equalize to water.
Tony
CSX4005LA
