  #50 (permalink)
Old 03-06-2011, 03:33 AM
Zedn's Avatar
Zedn Zedn is offline
Originally Posted by beauies View Post
Does anyone have the NEW CR Build manual in a PDF file or something similar. Would really like to have a read before i make a final decision?
From all your guys builds have you come across items or things that you can save a bit of coin with e.g are you better off getting a windscreen from CR for $1500 or from somebody else etc etc?
It depends on how much time you are willing to spend finding cheap parts and what skills you have.
Some examples of cost from my build
- I was about $10k ahead to begin with because my body and chassis was only $6000 second hand.
- $1500 for jag front and rear plus about $1k for shortened half shafts and parts to rebuilt front and rear including brakes.
- fuel tank $225 90lt stainless i fabed myself, $120 for walbro intank pump.
- windscreen $140 (+$140 cause i cracked it ) windscreen frame $50 in argon because i used the left over stainless from the tank.
- Wipers and motor $50 from a triumph wrecker plus about $100 for replacement chrome wipers from ebay (if you buy cobra wipers it will cost hundreds).
- Seats from RX7 that needed some foam repaired $50. Bought some foam for $20 shaped it myself and glued it on. Bought custom covers of ebay for $370.
- LS3 $7950
- T56 $1900
- Alloy radiator $320
- steering column $50 from pick and payless
- Wheels $2100
- Tyres $710
- painting i will do myself for the cost of materials (about $650)
This should give you a guide. I think paying for labour is what would really get the budget ticking over.
Whilst i have bought and made things cheaply, the thing you dont want to do is skimp on things. You can buy heaps of used parts off donar cars but i think it is worth replacing all wearable items such as bearings and bushes. I still plan to buy a proper replica windscreen frame, but mine will get the car on the road and then i can add that afterwards.
The stuff that gets you is bolts. They add up really quickly.
