All the hard work is already done for you. Block machined, rotating assembly internally balanced, bearing clearances checked, cam degreed, short block completely assembled.
Includes:
*Dart SHP Block, 4.125" Bore
*Scat 4340 4.000" Crankshaft
*Scat Forged I-Beam Rods
*Wiseco Forged Pistons w/ Moly Rings, 10.25:1 w/ 60cc Heads
*Clevite H Series Main/Rod Bearings
*Ford Racing Double Roller Timing Chain
*Comp Cams or Bullet Hydraulic Roller or Solid Roller Camshaft
*Felpro Rear Main Seal
*Painted, Freeze Plugs Installed
$4630
