Old 01-26-2002, 03:33 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Ford clutch, regardless of whose it is, mounts with 3 dowel pins, and 6 bolts. To the best of my recollection, they are 5/16" bolts. The dowel pins align and center the pressure plate with the flywheel. The bolts hold it in place. These should nave come in a hardware kit with the clutch. If not, get these pieces before installing clutch. Then use the flywheel holes that all 9 holes in the pressure plate line up with.
