Old 03-13-2011, 06:06 PM
blykins blykins is offline
You will get some noise with the aftermarket ones as well, probably even more so, as most of them aren't as NVH friendly as the stock pieces. That's why I asked that question.
An aftermarket shifter will make the transmission shift a lot better, but if there is an underlying problem, it will do nothing to help.
Did you make sure the transmission and engine mounts are good and tight?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
