I just installed Finishline overiders on my Backdraft. They had strap steel type mounts welded to the inside of the overiders which were threaded. All I had to do was locktite the threaded mounting rods to the overiders and slip them thru the body and into the mounts on the frame. I had to fabricate longer rods though out of grade 8 threaded stock as the orig rods were too short and were up against the body even before they went into the frame mount. Not to difficult a job just had to be patient so not to scratch the body or damage the fiberglass. Good luck and enjoy. I mounted my overiders so they were approx 1/8" from hitting the fiberglass. I liked the up close sleek look more then the extended look which would give it more protection. Just a matter of choice though.
