If it is truly a RMS, there's no need to remove the cap at all. Simply pry out the old one, and put in a new one.
You can get a number of seals from Fel-Pro, etc. Most of them have a metal ring that seals around the bore. They can be a real bear to install straight; especially lying on your back. For those types of seals, it's better to loosen the main cap put in the seal with some silicone on the otside edge, and then torque down the cap.
Of course, once you loosen the cap, you'll have to remove it, clean off the old silicone, and then install with fresh silicone sealant between the cap and the block. If that's where it's really leaking, I would R&R the cap anyway, just to make sure it wasn't leaking at the cap.
If you remove the cap, there's no need to loosen the rest of them. Simply go back and forth and tighten the cap in stages.
I use the Ford motorsports seal - i can simply slide it in with my thiumb, and it never leaks.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
