If you mount the alternator low, I doubt whether it will clear the upper control arm pivot shaft.
I've got to train Peter better to pack the adjusting bracket in all the small-block kits, since he seems to forget it about half the time. Probably because it's optional with the 427. (The difference is that the small-block bracket has no Ford equivalent, while the FE bracket does.)
