Yep... been there, done that. Got the GM alum thingys and the GM mounts.
To give you some idea, The bolt protruding from the top and the bottom of the GM rubber engine mount hits the very center of the chassis side rail, That chassis rail is a 4" section. Whereas in the pic posted by Boxhead that bolt is inside the chassis rail.
Further the center of the diff pinion is in a line 1" above the bottom plane of that chassis rail and is horizontal ... that is 0 degrees.
