Old 03-21-2011, 05:47 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Two engine builders have told me many new cars and new engines use the aluminium powder to take care of situations like your radiator. Every engine I have built or had built has had the bars stop leak put into the radiator just after the dyno. The radiator stop leak also serves as a lubricant for your water pump too. If you are going to track your car you cannot run antifreeze which among other things has a lubricating property. Buy a pint of the Aluminium Bars Stop leak and follow the instructions. I think you will be pleased. The StopLeak will also help with electrolisys of dis-similar metals (aluminium and steel) which is a whole different problem.
Clois Harlan
"Let's roll"
"Be part of Something Good
