Thread: Octane
Old 03-21-2011, 10:01 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Octane is predominantly used to control detonation. Detonation comes when the pressure or tempe is high enough to ignite the mixture before the spark plug can.
9:1 comprssion is pretty low, even at 1,000' ASL. The SBF generally can't make use of more than 35* or so of timing. Even with iron heads, the only time you might have problems is when it's really getting hot; like 220*+.
What's your cylinder pressure? Have you done a compression test? If you have a big cam you might be giving away a lot of power. 9:1 is stock engine range.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
