  #115 (permalink)
Old 03-23-2011, 08:23 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Centering the intake over the piston---that's one area that is hard to do on an FE unless you cut the head in the middle and lengthen it----not so difficylt on the windsors to off set head forward or back--
However---the bbc flowed better into the cylinder from the crooked port than the straighter ones---
With efi---will the rules allow you to reverse flow the engine? All the exhaust in the center up high where the intake normally sets???and injectors outside where exhaust was??
