Old 01-28-2002, 01:46 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Default How about AVO shocks?
Hi Gary,
I'm running AVO coil overs on my Classic Revival which uses Jag front suspension components. They have 1/2" spherical bearings in the ends and are externally adjustable without removing the shock (you can see the adjuster near the lower mount). It's a single adjustment for both compression and rebound. They are a steel body double tube damper and are rebuildable. They came with the aluminium upper and lower seats but I machined up the seat to go between main spring and the tracking spring. AVO shocks are made in the UK and I'm not sure where you would source them from in the US but some one must import them.
Mike Murphy
Melbourne Australia
