Old 03-23-2011, 09:54 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Mreid,
Maybe I am stating this wrong. I am simply stating that pressure at say with a Weber IDA 48 is only important because of the needle and seat.
So, if recommended is 3 psi and you run 2 or 4 psi you would probably not see a difference unless the needle has a minimum 3 psi cracking pressure. Also, if you exceed the 3 psi to 4 psi this may hold the float down from excessive pressure. If the previous condition do not happen then, there would be no difference in performance.
Correct?
