cowl hoop
the hoop was fitted and welded in place, if you look close most welds are only where you can see , look on the back sides and there are no welds. i removed mine by cutting the three 5/8" tubes that hold the dash hoop and rotating it out then flanged them to make them bolted. tigged welded all brackets cleaned and radius all corners, blasted and painted and reinstalled.
