Old 03-26-2011, 10:48 PM
STL Mark STL Mark is offline
Originally Posted by ramey View Post
mine was a 5/16 line with a volkswagen fuel filter... you have to pull all that garbage out and completely replumb the fuel system... the stock line is not even big enough for a return line.
if you go with the stock stuff, you are limited to about 350 rwhp, and if your motor wants more you'll burn pistons.
also, if you want to drive the car, the stock tank pickup will starve unless full in any corner... especially if you fuel inject the car.
you need to pull the tank and either put a cell in or cut it and put proper reservoirs in.
the car was just not designed to be raced. they are nice, but nice show cars.
All fine here too. Stock lines, Aeromotive fuel pump, pressure regulator - 650 hp - no problems.
