Thread: FE vacuum ????
Old 01-28-2002, 06:49 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Cool no problem..
You should have no problem.. I have a similar spec cam and I pull PCV and Vacuum off my 8v manifold. If you encounter stiff braking (not always a bad thing) put an inline check valve between your brake booster and manifold. The booster will then be isolated from manifold flucuation and store vacuum for the times you need it.. (you should run one either way whether you need it or not...)
Regards,
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
