Originally Posted by PANAVIA
Here is what we did on 2734'
Seat Cushions de-foamed by about 50%
Seat frames widened and tilted with a hydraulic bottle jack and some work.
Seat tracks removed and seat bolted to floor in rear, and a 1" aluminum spacer inserted under the front bolt tabs between the tabs and the frame, tilting the seat back a bit.
this , combined with the proper footwear makes 6'3" 290lb me -fit in a SPF.
--Steve
Outstanding suggestion. I think moving the seat back and bolting to the floor would definitely be in order due to height. Then if I diet about three weeks at wife's behest I should be good to go, unless I buy a used SPF with a seat like Dennis described. More drastic alterations may become necessary, like grease the seat with Crisco and drive naked!
