04-02-2011, 01:22 PM
SI
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Rather than shorten the E-Tube, I would simply fit a 1mm thick washer between the main jet & E-Tube of those that are sitting lower, therefore bringing all the E-tubes UP to the same height. Should be able to get suitable washers from a model car/plane shop or electrical repair firm that actually does repair work instead of sending it away to a major service 'center**** Do they still have shops like that in USA??
Down side to anything you do is you will always have to remember which bits come from which carb.
Jac Mac
