Originally Posted by WardL
I understand oversteer and understeer, no problem. So this TT only happens when going into a corner near (or maybe over) the limit of you and the car, you are braking and do your down-shift and voila! your back tires break loose and you spin out before hitting the gas as you would coming out of the corner. Thanks again!
Nope,you still don't get it.
It is about being at or near the limit in a corner/curve and releasing the throttle.
