04-03-2011, 10:18 PM
AZ
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by Barnsnake
Here's another way to look at it:
Say you are taking a corner at, or near, the limits of adhesion. If you lift off the throtle, some weight transfers from the rear tires to the front tires (since your center of gravity is above your spindles). Cobras with drivers have a considerable rear axle weight bias. When the weight transfers to the front, the heavier rear loses its grip and you proceed off the road backwards.
911's and other short wheelbase, tail-heavy cars also have this tendency. Running larger tires on the rear helps a bit, but doesn't eliminate the possibility.
Barnsnake, here's one for you, if as an example I carry a significant amount of weight like 200# in the trunk coupled with my own weight 225#'s centered in the car, does this phenomenon still occur? In other words what is the empirical fix, if indeed there is one, or does in matter since the tires will still break loose?
Cheers, John, AKA, tin-man
Be well, drive fast, live long
