Old 04-04-2011, 05:21 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by mreid View Post
Definitely trim the bottom of the bellhousing. Gives you some piece of mind, plus your car will settle a bit as you drive it and you may find that without any adjustment you find yourself at 4 1/2" ride height over time.
I took a look at trimming the bell housing, but unfortunately, the bottom of the sump/oil pan is at the the same level. So trimming is out of the question, as the sump would then take the impact. That would be bad news as it will distort the seal area too.
I am installing sloping rubbing blocks to the frame. In an event where I bottom on something the frame/rubbing blocks will just glide over without impact to the sump. Providing the hump I'm going over is reasonable flat. LOL
Arthur
