Matt: When I did my install I too noted quite a bit of an angle with the driveshaft installed and offset the problem, to a small degree, by shifting the entire engine and trans slightly, emphasis on slightly, to one side. Still a considerable driveshaft side to side angle when all is said and done but to date I've had no problems in terms of vibration at high (or low) speeds. My number is SPO 2820 so it doesn't look like the factory has done anything to improve on the situation. Hopefully the thinking is that modifications are not necessary and the driveshaft angles that result are okay? Here's hoping.....
